Yes, you are right. I do want the bumper slimmer and curved to the shape of the body, extending around the sides a bit. I figured on having them mounted directly on the current bumper shocks, but it would be more attractive to avoid having that large mounting plate. In that case, there could be solid mounts that go right back to the frame, where the current bumper shocks mount. That would make sense. I realize that the shock absorbtion will be gone, but at least it would be as effective (or better) than the chrome bumpers.Just brainstorming, but what did you have in mind for lighting and signals? The reason i ask is that i could fabricate some sort of housing, clamp, or even have them inset into the tube...
Also, would you want to have the tube bolt on or welded...that will have to be considered.... to figure out whether or not you would need to send the bump shocks to me...
Also, how much wrap around would you want...
The curve, as I said, should follow the body line as it goes around the side, and end perhaps two inchs ahead of the wheel well. It would be important to keep the bumper level as it goes around, so it doesn't look droopy or angled upward at the ends.
Essentially, it should follow the line of the old chrome bumpers, but be a slim tube. Then it could be color-keyed to the car, powder-coated in black, or maybe even chromed - or whatever. I do think the tube ends (near the wheel wells) should be bullet shaped, or perhaps a bit flattened and rounded - something graceful and fitting to the design of the car, rather than squared off (and thus looking like a bent tube
As I said, I've yet to consider the back bumper, but probably something similar. By the way, the front tube bumper must weigh at least forty pounds. I should weigh it - or maybe someone knows. It is a monster and even a twenty pound replacement would be a big help.
