Flexible coupling removal.
Nut124
Re: Flexible coupling removal.
Post by Nut124 »
SpiderGuy wrote:Has anyone ever found a source for the (Giubo- aka- Coupler) Compressor Tool as shown in the Service Manuals?
Fiat Part #A.70025 or Kent-Moore #J28087
I did a google search and was not able to find either one.
I need to replace the Drive Shaft Center Pillow Block and Bearing because it is completely broken and the Drive Shaft is flopping loose.
I replace mine about 2 years ago. I seem to recall the replacement donut came with the clamp around it. I would have bought it from either AR, Vicks or Midwest Bayless.
You will not need it to get the old one out though.
SpiderGuy wrote:Ill take note of the bolt orientation like you said
Let us know how it works out, Keith. If all is well, then, well, we make a-pizza! Delizioso!
