One down, one to go
The brake cable is visible in your photo hanging just below the brackets and must be dragging on the ground. Hopefully the rest of it is still hanging from the parking brake lever including the springs. Hopefully you have not driven it around much like that as a lot of damage can be done if the cable gets caught on the ground or wraps around the drive shaft or one of the rear wheels. If the cable has rubbed on the drive shaft it can leave the drive shaft scored and prone to shearing off at that location.KLC356 wrote:Perfect. The ebrake was dismantled- so this makes sense now!
