Timing Light Power Connector
- MikeHynes
Re: Timing Light Power Connector
When I set the timing on my Spider I power my timing light with one of those booster jumper batteries. Easy!
- Turbofiat124
- Your car is a: 1980 Spider 2000 turbo
I've always just connected the positive lead from my timing light to the + side of the ignition coil, then grounded the timing light to the coil pack, engine or frame. I've never used the alternator post to supply power a timing light or tuneup tach. Just curious but what's wrong with getting power from the ignition coil?
I don't have one.
Compu-Tronics dual Coil Pack.
I cut off the power clips on my cheapo timing light and spliced in a power plug for the cigarette lighter. Works well. I used to clip to the stud on the alternator, but managed to short out the clip during timing one day. More excitement than I wanted.
Kirk
Kirk
- Nanonevol
My timing light plugs into the wall.
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
1985 Jaguar XJ6
1966 BSA Lightning
You must have a good one.
