Bumper Removal
Re: Bumper Removal
I was asked if the car had the bumpers removed or modified when I insured mine and have seen notices about reduced coverage and potentially having the policy canceled for the lack of or modification of bumpers on other policies in the past.
The insurance question is something to consider.
- Your car is a: 1979 Spider 124
Re: Bumper Removal
Dang it...I as debating on whether to remove them or not...they look so sexy without them...but yeah, I bought this thing to drive, not show, so maybe it's best to keep them on...
Thanks for the discussion, everyone.
Re: Bumper Removal
I signed with Hagerty a couple weeks ago. NO pics required for their standard agreed value of $10,400. Being it's over 2x what I paid for the car a few months ago I didn't attempt to increase their agreed value and provide pics.Exit98 wrote:Pete,
Hagerty's for one requires pictures of the car for agreed upon value insurance. So presumably if you send them a picture of your bumperless Spider and they insure it you are OK.
If it had bumpers when you insured it and then took them off it would be very wise to update the insurance pictures.
All insurance companies will deny a claim if they were lied to or otherwise decieved.
Re: Bumper Removal
I signed a month ago and had to send one side photo. It was a poor photo and didn't show bumpers and they didn't care.
They actually rejected my 75 cj5 and said it needed to be "more complete". the windshield frame was off - they are supposed to do that on pre-76 - and the paint job is ugly right now. But What old beater jeep isnt?
Re: Bumper Removal
You really have the read the fine print because some agents are great about telling about the exclusions and gotchas while others are not. Some may put it under excluding coverage when safety equipment is removed or have some other crafty legalease that excludes coverage. Some even put it as configured for racing or practice for racing.
- Your car is a: 1980 pininfarina 2000 fi
Re: Bumper Removal
In regards to the turn signals, I placed mine in the square openings under the headlights. Granted, they won't fit in the holes. So I just have them pressed up against the inside of the holes using some metal strapping that's bolted to the shock mounts and screwed into back of the turn signals. Maybe someday I'll upgrade.
Re: Bumper Removal
I purchased the LED headlamps with turn signals from Allison.
I replaced my broken grill with radiator cover mesh from Lowes? And had lots left over to cover the holes.
The front bumpers were no problem, the back... I had to shift the tank a lot.
But it's done and I'm happy with the results.
1979 Fiat 2000 "Luigi"
- Texafornian
Re: Bumper Removal
For those who had to move the tank to remove the rear bumper, did you have to disconnect the hoses, including filler, or could you wedge it with those attached? Does anyone have a photo in-progress?
Daniel
Re: Bumper Removal
have picsTexafornian wrote:For those who had to move the tank to remove the rear bumper, did you have to disconnect the hoses, including filler, or could you wedge it with those attached? Does anyone have a photo in-progress?
I disconnected everything I could; capping each part. Get all the gas out that you can; there's lots in the reserve and it weighs a lot.
2x4 did the trick, I'm pretty sure I had some 1x2 as well.
- Texafornian
Re: Bumper Removal
Thanks - I guess the main one I am concerned about is the filler. I'd love to see your pics.
Daniel
- Your car is a: 1985 Spider
Re: Bumper Removal
I did mine without dis-assembling anything. Just removed the nuts and lifted the tank enough to fit a 1 x 4 under it to help lever it up.Texafornian wrote:Thanks - I guess the main one I am concerned about is the filler. I'd love to see your pics.
Don Avery
Dayton, OH/Sarasota,FL
1985 Pininfarina
2011 Eos
2012 Mercedes E550 Cabriolet
1985 Pininfarina
2011 Eos
- Texafornian
Re: Bumper Removal
Thanks Davery. I'm going to give it a try tomorrow, wish me luck. Any pros/cons with using a jack to lift from below?
Daniel
- Texafornian
Re: Bumper Removal
Success! But I was scratching my head for a while until I realized one of the bolts on my fuel pump standoffs was blocking me from lifting out the tank. And the kicker is I was so focused on the goal I forgot to take pics! Well, here is the finished product:
https://1drv.ms/i/s!As0M4aC9epz5n_Z0r8zAv-q0q0leOA
Daniel
Re: Bumper Removal
Looks good! Just gotta finish up the trunk now lolTexafornian wrote:Success! But I was scratching my head for a while until I realized one of the bolts on my fuel pump standoffs was blocking me from lifting out the tank. And the kicker is I was so focused on the goal I forgot to take pics! Well, here is the finished product:
- Texafornian
Re: Bumper Removal
Done! Or at least done as it is gonna be
Spare returned check, boards in check, rubber mat check, dump all my spare parts in check...lol
Daniel
