In the mean time as with most 124s the electrical system is showing its age. Despite a 65A alternator electric things are slow. On cold and rainy evenings with the heater fan, wipers and headlights the system really struggles. So I figured I would swap out the bayonet style fuse holder for a fuse / relay panel. Here is the wiring diagram for the early sedan, its amazing how much runs off that first fuse!
To get this going I picked up a 2000 Jeep PDU with wiring off ebay for ~$5, a bunch of Metri-pack 280 crimp connectors and a Cooper Bussmann 15303-4-0-4 Mini Fuse Panel. Despite being called bussmann this panel has no busses. I picked it out to have the most flexibility but in retrospect I could have gone with a buss relay side and saved some wiring. Here is a pic of the panel and some of the wires after pulling them out of the PDU.
Here is the wiring diagram I cooked up, I tried to label the color wires from the existing Fiat fuse bar:
I think technically I should have the fuses before the relays but for the high & low beams I wanted to keep a R/L fuse but only use two relays so I put the fuses after the relays. The relays are 30A and fuses are all <=20A so I think they will blow before the relay melts.
I also want this to be close to drop in for the existing fuse bar, I'm not looking to re-wire the whole car!
I left one relay & fuse for future accessories, thinking usb charging port, blue-tooth amp etc.
The last relay I was leaving for the fuel pump ( right now the electric pump is wired to the ignition ) but I am not sure how this would work with the Fiat's oil pressure switch, only posts here I could find were talking about needing special timer delay relays....
