How complete was the unit? Plug and play or are there additional parts/setup required? I see some specifying that they are "Complete: Headspaced and shimmed, 3.90 ring and pinion with the bearings installed". Was a new third member to axle housing gasket included?Squidders wrote:Just having a similar issue were the diff was getting progressively noisier and has since failed. I decided to swap out the third member and am keeping the old one as a back up (repairing it later). I purchased mine from autoricambi and had it shipped to Aus. While replacing it I will be swapping out the rear wheel bearings as well as I don't know how long ago they were done. Will also be going from 4.3 to 3.9 as one of the PO's has swapped the diff and axial to to earlier model spider at some point. Will be good to get a better Highway run with less RPM's and better economy.
Vics has it for $40 than AR more however if its more completely setup then its worth it.
Mine is pinging and more than likely a 4.30 which is not that great with the Diesel as that originally was in a car with a 3.38 so I am hoping that going to a 3.90 will be a more livable compromise.
