Transmission Swap
kacperix
Re: Transmission Swap
Post by kacperix »
thx for the answer,
at this stage i am looking somethinkg plug&play more less :) so i choose polski fiat/polonez gearbox and update some parts.
Gearbox for polski fiat i can have for 30-40 $.
When i will start complete body paint work, maybe i will do it... i found also some pictures hier:
http://www.mirafiori.com/faq/content/13 ... nsswap.htm
djape1977
Your car is a: 1970 fiat 124bc
Post by djape1977 »
this link pictures the "half assed" way of doing it. it's more complicated if you want it done right.
regular 124 gearbox will work for a while, if you get it properly rebuilt. recently, biggest issue i have with rebuilding these is finding good quality bearings. matket is overwhelmed by cheap sh*** quality bearings
kacperix
Post by kacperix »
so gearbox is exchanged/swapped from polonez polish car, mostly based on polski fiat 125p,
there are some upgrades changes needed like:
1. front of the chest bell
2.runners (3pc)
3.rear lid with gear change mechanism
4.do box fits perfectly set of seals from the polonez - beyond the seal at the top of cover, that he had cut the tracing elements.
at the speedometer drive gear - exchange is not always necessary
polonez 1500 were bridges 10/41 - like a glove to older spiderków.
polonez 1600 were bridges 11/43 - 3.90909 ... that is basically the same as spider2.0 (3.9).
