Dropping the cross-member down two inches..then drop spindles...how much clearance do you have between the oil pan and the ground?brad302 wrote: To get motor to set lower we cut the front cross member out and lowered it by two inches. This allowed us to lower the motor and the center line of gravity. Now the cars up higher so I lowered it back down by converting the A arms to hold a Chevy S10 2 inch drop spindles. Plus I was able to match the bolt pattern of t he Chevy rear end that it now has. Sorry I don't have many picture of the build. If I find some pictures I try and get them posted. Thanks Brad
Thanks!
Rob
