All I can say is WOW!!
RoyBatty
Your car is a: 1975 124 Spider - 1971 124 Sport Coupe
Re: All I can say is WOW!!
Post by RoyBatty »
Preachin' to the choir my friend.
:D
steviebsf
Post by steviebsf »
that is a fantastic thread. read every word.
and i have zero interest in going to carbs from FI :D
...love this forum - cheers
bradartigue
Post by bradartigue »
This is an interesting thread, reminds me of 20 years ago and thinking IDFs were an upgrade...now I know better :)
IDFs can't compare to fuel injection, even L-jetronic in its tuned-for-economy mapping is more efficient and yields more power on a stock engine. IDFs can't deliver the amount of air/fuel with such accuracy as a FI system, though the sound they make may put a smile on your face. I think someone switching from FI to IDFs would be very disappointed; if not, then their FI wasn't working correctly.
MrJD
Your car is a: Looking to ask questions about a 79 2.0
Post by MrJD »
I'd bet you could set up some individual throttle bodies and FI (megasquirt) for similar money to a good IDF set up. Then you'd be talkin best of both worlds. :)
bradartigue
MrJD wrote:I'd bet you could set up some individual throttle bodies and FI (megasquirt) for similar money to a good IDF set up. Then you'd be talkin best of both worlds. :)
Absolutely. Use IDF throttle bodies on a stock IDF manifold. You could use the stock, or better yet, drill for newer type Bosch injectors. Use megasquirt and a good ignition system. You could be otherwise stock (cams, pistons, etc.) and create a real nice setup; outside of stock, esp. with HC pistons, you could create a monster. I'd love to try this, just need a test mule and a bigger garage.
Redline
Your car is a: formerly a 1971 Fiat 124 BC Coupe
Post by Redline »
I also have this in the back of my mind for whenever I feel like playing a bit more with the car. The only doubt that I have is doing it for the same money as the IDFs.
http://www.124bc.com
