Edit... Resto mod FIRST DRIVE
- MrJD
- Your car is a: Looking to ask questions about a 79 2.0
Re: Engine bay coming together
man... that looks amazing. Taking down my whole engine bay and re-doing itmight be a project for next winter... want to get the car on the road atleast a little this year...
Daniel,
It's a mid 80's dodge omni rack. I've done my best with the measuring and layout and hope that I am in the ballpark. I have not posted much about it since I have no idea if I can make it work. Once the beast is on the ground and moving I will post about the install.
Andy,
Ok, that was all way over my head!! Google will be my friend tonight while I figure out what you are talking about.
JD,
Go for it while you have your car half apart!! No time like the present, unless you're talking about what Andy said, then PROCRASTINATE!! Haha!!
I got a few more bits hooked up... Fuel line and fuel pressure gauge. Also tapped my breather hose into the air box.
Andy,
JD,
- toplessexpat
Seriously - I'm so impressed with the work you're doing.... I'm going to drop in next time I'm in FL.
My electric ramblings be dammed... do it your way!
That sounds perfect Andy, come down and explain the electrical in person! Do you get to Florida often? I would enjoy meeting you! That said, I am hoping to make the hill country run next year with this car. Sounds like a trip worth making!!
I've been curious, how's the upholstery coming? You have more guts than me!
- toplessexpat
I'll post on the seats when I'm at home. A few of the local Houston guys seem to think they're ok, and probably worth putting up a couple of pictures on. Basically - take your time with them! Your front end with those 5.25" lights - now THAT is brave.
The hill country trip is well worth making - and I'm trying to convince Mike to let us to a TDS stage in 2015.
I do get down to Florida from time to time - I think the wife wants to drop down to Miami sometime soon, and I'm sure I can find an excuse to get out of there!
- MrJD
No way, I've only driven the car 3 times. I'm getting it back on the road for some fun before anymore projects!
Andy,
How about this?
http://www.protuninglab.com/7dicutroprh ... 8283950120
7" headlight with option for HID and integrated DRL. pretty sure it's a plastic lens which I don't particularly like.
My simple solution for DRL on the 1977... I just leave the headlights on all the time
How about this?
- toplessexpat
I had something similar - then the lens melted with H4/55w bulbs!
I took some correct OEM glass fronted lights (thanks AR!) and retrofitted the parking(drl)/turn signal bulb holder via a 1" hole in the top of the housing. Like all good plans that's changed a little now as I've found some vw units that appear to fit the "square" holes nicely so I'll be swapping for just a parking light again in the main headlamp.
For HID, I found some pre owned Audi units which avoid the low quality color issues of some of the cheaper ones you can get off eBay etc, and I'm working out how to get the self levellers working.... Plus you'd get that cool effect when you power up and the lights "rake" up as they reset...
[quote="SoFlaFiat"]Daniel,
Thanks we have a post somewhere about this topic and what rack to go with your experience should be a great help
if the car is happy with the transplant...
Wow Alan, that really looks nice
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Andy,
The "rake" does sound cool! Make it happen and show us how!
Daniel,
The minute I know this thing will go down the road and I don't need to tear it apart and reengineer, I promise to post what I have done. Just flying by the seat of my pants a bit and don't want to lead anyone in the wrong direction if that's the way I have gone.
Thanks Jim!!
And today, I mounted my fuel pump and ran the fuel line up to the engine bay. I have clamps on order so for now... Clampless!
Every day a baby step closer...
Daniel,
Thanks Jim!!
- Your car is a: 1978 cs2 spider
looking good!
Thanks guys!!
Ok, now that I ran that fuel line, it strikes me that I might want a check valve in it to keep the fuel from draining back. Any ideas on what type and where in the line it should go? Or, do I need it?
- kmac33
- Your car is a: 1974 Spider
Wow! Great work.
Kevin McMullen
1974 Fiat Spider - Restoration Complete! But the mods/refinements continue
1980 Fiat Spider
2013 Subaru WRX
1980 Fiat Spider
2013 Subaru WRX
