Primary connector from wiring harness on driver's side...
Another picture of the driver's area...
I've got light green, blue/black striped, white, black, yellow/black lines, red, yellow/red lines.
According to the diagram it should be black, white, red, light blue/black, light blue, yellow/black, yellow/red.
Not sure what to make of it. I'll look at the other diagrams and see if something matches closer/exact.
And the driver's side works perfectly. So maybe I should worry too much about the colors. And just trace it through to the other side.
I did another test as well. I disconnected the main connector on the driver's side, touched the ground post bolt and got connectivity on all but 1 of the wires on the main connector that comes from the hiring harness to the driver's light fixture. Does this make sense? I thought from the ground post to the wires I should only see the black one have connectivity with the ground post. What am I not understanding?
