best oil?
Re: best oil?
Post by RRoller123 »
This may be a dumb question, but do you guys use the diesel oil?
bradartigue
Re: best oil?
Post by bradartigue »
RRoller123 wrote:This may be a dumb question, but do you guys use the diesel oil?
Rotella T is marketed an oil for diesel and gasoline engines, but the specifications for it exceed FIAT's requirements. So yes.
Re: best oil?
Got it. Thanks. I have been using Castrol with a zinc additive. No additives needed for the Rotella?
KidDingo
Your car is a: 1981 Fiat Spider 2000 FI 5-spd
Re: best oil?
Post by KidDingo »
I haven't been using any additives.
Yesterday I came across a statement in a third-party manual for the Bosch L-Jetronic FI system which very clearly said to not use fuel additives in the fuel tank because they will pass through the fuel pump and cause damage to it.
I know oil additives don't pass through the fuel pump, and modern additives have evolved a lot, but I prefer to not use them for that reason - you just never know. Others have experienced great benefits from additives with no harm done, though.
_______________________________________________
Michael
Leonard124
Your car is a: 1980 Fiat Spider 2000
Re: best oil?
Post by Leonard124 »
Don't know if best oil but using 15W40 Rotella most of the time
Leo
1980 Fiat spider 2000 f.i.
Nanonevol
Re: best oil?
Post by Nanonevol »
Just changed oil using Shell Rotella as advised by some here on the forum but read elsewhere that it may have been reformulated and doesn't have the required zinc anymore. Valvoline was recommended. Anyone using Valvoline?
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
ORFORD2004
Re: best oil?
Post by ORFORD2004 »
Valvoline VR1 20W50 for me
Frog2Spider
Your car is a: 1981 2000 Spider
Re: best oil?
Post by Frog2Spider »
Google 'Kieth Ansell on Zinc in oil' and read what this man has found and re-searched fully on the subject of oil, zinc and flat tapper engines. He's been in the auto restoration business for over 40 years. Then decide for yourself.
I use Cheron 10/40 with 4oz. of ZDDPlus. Likely bad for the Cat, but we don't need to EPA test our old cars here, and even if we did, a Cat is a lot cheaper than an engine rebuild.
Dave
Frog2Spider
'81 - 2000 Spider
baltobernie
Re: best oil?
Post by baltobernie »
Hemmings Classic Oil for me. The amount of zinc and phosphorus are stated. $9 per qt. delivered to my door.
http://www.hemmings.com/classic-oil/20w50
