Switching From 4-link to 3-Link...
- v6spider
Re: Switching From 4-link to 3-Link...
The frame is finished for the third link..just needs to be cleaned up and welded in place..
http://www.v6spider.com
- v6spider
Third link all welded in... just have a few more things left to do on the underside then I will be rolling the car back off of its side taking it out of my frame work supports and working on the suspension..
- v6spider
Here's the completed modification to the rear end. The original mounts for the two upper links were removed. Center mount added for the third link to the torque side of the rear end.
- v6spider
So here's the third link almost finished up. I am working on pinion angle so I'm going to set the engine and tranny in their mounts so I can install the drive line and check the angles out. I am thinking I need to shorten the upper link.
Here's the ride height I am shooting for in the rear...
That's looking sharp Rob!
Is the overall tire diameter larger than stock? It fills the wheel wells very nicely!!
- v6spider
Yes they do! and yes they are at the limit of what I could stuff under there at P225/50/r15. The wheels are an out of production Enkei RP-01 model that is powder coated. They are little dirty right now, a good cleaning will do them justice.SoFlaFiat wrote:That's looking sharp Rob!
Cheers!
Rob
- v6spider
Just as I thought.. Pinion angle is too high..
