Another lesson learnedredcars wrote:Those bent over brackets on the nuts are called locking tabs and are bent over to prevent the nuts from coming loose and ruining you day while you are crusing down the road.
Thanks, hopefully get this done tomorrowdjape1977 wrote:remove the hub from balljoints. hammer out the bolts. no other way to do it, it was intended to be done that way
