Fall/Winter/Spring Projects 2012/13 for Fiona RESOLVED
Re: Fall/Winter/Spring Projects for Fiona
Did not even need spring compressor.
Followed this video http://www.youtube.com/watch?v=c1akqSJE ... plpp_video & it worked like a charm
You know that old saying " they don't build things like they used to" well holy crap "they" are correct
Could not get the nut off to save my life, then it moved but it was just stripped SOB. Let the cutting begin
Got 3 out of 4 bolts out arggggggggggggghhhhh
The control arms on the other hand were in desperate need of replacement.
Im in Melbourne Australia4uall wrote:@ westy64 I have not tried yet (cleaning/painting the sway bar) however, in retrospect I should have put the bushings on the bar then add the mounts
hopefully with enough grease/lube they should go on without any issues
@PininF I have heard of people using storage places. Where are you located? Where do you park/store your car?
Only just got this car, will be moving next year so till then my baby will be in the drive way under a cover for the winter
Will be posting pics of total restoration soon, the roof is already off so is the hole front under carriage for complete replacement. What have we gotten ourselves into Couldn't be happier
Cheers
John
partial success broke two Colbalt bits in the process MOTHERTRUCKER
Now this is the next bolt to tackle
unbelievable what you have had to go through with this!
I have to laugh out loud, because when this is all said & done, I still have the passenger side to do
I wish I
a) had welding tools
b) knew how to weld/torch
C) had easier projects to tackle
I wish I
Might be worth just buying new parts, the A-arms with the ball joints already installed, etc?
Too bad about the lack of welding stuff. Great candidate for the welded nut trick.
Broken stud in the manifold
Place nut over broken stud
Weld stud to nut.
After a bit of cooling, carfully back and forth to loosen nut
Might take a couple of attemps, but does work
Weld stud to nut.
Have all new upper and lower control arms for both sides ready and waiting however, I still needed the brake shield and steering knuckleRRoller123 wrote:Might be worth just buying new parts, the A-arms with the ball joints already installed, etc?
Looking to have it torched out this week
- KidDingo
- Your car is a: 1981 Fiat Spider 2000 FI 5-spd
Hi Jay
Will be tackling the same job next year.
Quick question:
What jack points did you use to keep the car up?
I usually put stands beneath the suspension points, but, obviously, if you pull the suspension apart, the jack points go, too.
Quick question:
_______________________________________________
Michael
Michael
@KidDingo I use the factory jack stand points
The front jack point by itzebtze, on Flickr
When I first started (last year) I did not use the correct places however, quickly put in correct locations and no damage done. Here are some good links
http://www.fiatspider.com/f08/viewtopic ... ack+stands
http://wwwl.fiatspider.com/f08/viewtopi ... &sk=t&sd=a
No need to say to be very careful pulling and pushing on things when the car is up on the stands...... It is easy to forget.
I also recommend some solid blocks/tires on rims, etc just in case
Free at last, free at last Thank God almighty you are free at last
Special thanks to Dave Stoddard http://www.davestoddardautoservice.aaro.ca/ in Ottawa. Took them less than 10min Told them I would probably be back with the passenger side
