Rear end ratio
Re: Rear end ratio
Post by RRoller123 »
185/70-13
baltobernie
Re: Rear end ratio
Post by baltobernie »
Me too, and we're seeing about the same discrepancy in speedo error.
Keruth
Re: Rear end ratio
Post by Keruth »
Ah, folks, tire size is the most common mistake on speed discrepancies you can make. The original tires were 165/80/13 and 185/70/14. I was 8mph off low with 165/60/13's. Cured that with a set of 15" Rota's from Allisons and some very sticky 195/55/15 BFG's. Local Gendarmes concurred!
I would like the smaller ratio rear gears anyway, should save gas too!
