Well that clears that up! Thanks. Now just have to find the right unterminated wire under the dash to pull on and see if it works! <{:^)
Pete
Trunk lid won't open
Re: Trunk lid won't open
The factory installed emergency release in a gray plastic covered cord or possibly a flexible wire. It terminates in a loop, up under the dash on the driver'e side.
Probably a shame that Pinnins never installed a remote boot/trunk release like they did with the Alfa, with a actuater in the driver's door clash. (so it was hidden when the door is closed/locked)
- Your car is a: 1978 fiat 124 spider
I needed to get into the trunk of my project car. I had no keys for trunk. I have a parts car with a good lock cylinder and key. I didn’t want to drill any holes so I opened the trunk on the parts car and bent up a tool to access the latch lever through the upper right license plate screw hole. When contacting it properly it required a pushing action (when using the key you must turn it counter-clock-wise). It worked good. I used a piece of stiff wire about 1/8” in diameter. I’m am trying to attach some photos
- cmurakami
- Your car is a: 1982 Fiat Spider 2000
If you could post a picture of the tool you created that would be great. I just locked my keys in my trunk and will be attempting to open it via the hole-in-the-top-right-of-the-license-plate method. Thanks!Jeeptechfred wrote:I’m am trying to attach some photos
1/4" hole, as indicated, go in with an awl, and rock it side to side to catch the lever arm and open the latch.
I'm not sure I like the idea of a rear trunk release that runs to the passenger cabin. On my car it would make opening the trunk a two person job as one pulled on the cable and the other slightly depressed the trunk. Seems that if you drill the small hole using the license plate method, you could install a small rubber grommet around the metal and have a pull wire there as well for emergency access.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
Grommet, YES! And that plus the license plate hide the hole. Easy Peezy.
- cmurakami
As an update, I used the drill-a-hole-two-inches-down methodology and it worked like a charm. I couldn't quite get the hole-in-the-top-right-of-the-license-plate method to work so decided a small hole behind the license plate is a small price to pay for trunk access.
Thanks!
Thanks!
I just rubber-plugged the tiny hole behind the licence plate,...in case future access is ever needed.
But I also fixed the reason for no access - broken plastic trunk-release-arm. I fabricated a replacement arm from scrap stainless,...it's better than original (or replacements), by far!
1988 Mazda RX-7
1979 Fiat Spider 2000
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
