3.58 Gear Ratio, pre '79
- aj81spider
Re: 3.58 Gear Ratio, pre '79
I can't comment on your pictures. However I have a 4.3-1 and I'm not a fan. I'm shifting from first to second about halfway through the intersection and I'm over 4000 RPM at 70 mph. If I could convert to the 3.58 I would in a second.
A.J.
2006 Corvette
2006 Corvette
- maytag
76 didnt have an automatic. I think if you have a 4.3 rear end and you rotate the tire once, the drive shaft will rotate 4.3 times. Or it might be the other way around.
- maytag
- maytag
- 124JOE
yes ive had the 4.3 up to 100mph bearly
it was screeming 5,500 on the tac
and wouldnt go any faster
these are made for good take off not top end speed
- FiatMac
Here’s the math.maytag wrote:so, I'm not a math guy. My brain shuts down. So somebody help me here:
chocked one wheel. turned the input at the diff 10 times. here's what I get.
the one currently IN the car (that my gut says was for a '76 Automatic) gets 4.5 turns of the wheel for every 10 turns of the driveshaft.
the one I have that came from the '78 gets 5.25 turns at the wheel for every 10 turns at the driveshaft.
What does that make the ratios? whatever it is, the one currently installed is the lower-geared, and I've been happy with it. So I'll probably refurb it and keep it. I'll need to find a panhard bar, as the current one is 'dun'. (I might toy with making an adjustable-length version out of it)
Anyone know the procedure for replacing bearings & seals at the axle for the non-removable-cover type? I mean, what holds-in the axles? Do I have to pull the pumpkin?
The gears in a differential are arranged such that the average speed of the two wheels multiplied by the gear ratio is a constant. In equation form this would be:
Differential Input Turns = Gear Ratio(W1 + W2)/2
Where Wl and Wr are the revolutions of the Left and Right wheel respectively.
So if the rear end ratio is 3.58:1 and we are traveling in a straight line with both wheels turning at the same speed W, then for each 10 turns of the input we can solve the equation by substitution:
10 = 3.58(W + W)/2 = 3.58(W)
Or
W = 2.79 turns
If we are trying to determine the rear end ratio by chocking(holding stationary) one wheel while counting the turns made by the free wheel with 10 turns of the input shaft, then the equation becomes,
10 = 3.58(W + 0)/2 = 3.58W/2
Or,
W = 5.59 turns
Below is a list of this calculation for each of the available ratios.
Rear Ratio /Free Wheel Turns per 10 turn input
4.3 / 4.65
4.1 / 4.88
3.9 / 5.13
3.58 / 5.59
Maytag,
Not sure how accurate you were with your count, but the 4.5 count for the ‘76 is very close to the count above for a 4.30 rear ratio. The 5.25 that you got for the ’78 is closest to the count above for the 3.90 rear ratio. You can get better differentiation between the numbers if you use a 20 turn input count.
Stan McConnell
Retired Mechanical Engineer
Salisbury, North Carolina
82 2000 Spider (driving)
78 124 Spider on the rotisserie
76 124 Spider parts car or possible Lemons racer
83 parts car
83 parts car
- maytag
if your motor tops out at 5500 rpm you have more problems than rear gear ratio
- DocGraphics
Fiatmac
Thank you, I will be using this to figure mine out too!
Don Raugust
The '76 is a 4.3.
The '78 is a 3.58 from an auto or a 3.90 from a 5 speed. To verify, remove the rear cover and check the ring gear. The gear ratio will be stamped on the side of the ring gear.
As far as the panhard bar mounting goes, I dont know. You would have to check with someone that has been around these cars for a much longer time than I have.
100 MPH with a 4.3, doubtful. 3.90 or 3.58 possible.
Jason
Jason
- boogiedude
- Your car is a: 1978 spider 1800
I've got a 4.3 in my car and I've taken it up over 6grand in fifth. I didn't hit 100. I don't think your speedo is accurate, I know mine is up into the 70's(I've checked it on speed signs124JOE wrote:yes ive had the 4.3 up to 100mph bearly
With stock gears and engine my old car topped out at 108 mph.
I assume you know that the panhard rod is seriously bent and needs replacement?maytag wrote: In my 76, I found this:
