SunnySideUp wrote:I did something similar to Razooli's modification of the stock air box. Rather than an enlarged slot I opted for a series of large holes in the front and down the fender side. I left the rear and engine-side of the box alone to keep the amount of hot air ingested to a minimum. It looks totally stock and folks at the DMV haven't a clue since they can't see it.
Good job! Gotta keep the DMV in the dark!
I thought I'd post the finish of my air box mod. I read Jason Miller's blog entries on his fabrication of a custom air box for his coupe (
http://www.millersmule.com/blog/project ... 1-forming/) and got inspired to replace my "cardboard and duct tape" connector with something more elegant. I enlarged the hole in the front panels and made a custom fiberglass connector that fits tightly between the panel and the stock air box.
I fabricated it around a foam core and then glassed over the inside of the foam to form a "throat" to smooth the air flow and insulate the incoming air from the hot engine air. There even seems to be a "ram" effect ... the temp inside the box measured above the filter drops 20° or more when the car is in motion vs idling.
SunnySideUp wrote:Modifying the stock air box produced a notable difference, not neck-whipping, but notable. I purchased K&N panel filter ... even get that guttural growl sound from the intake like one would get with a cone filter when you punch the accelerator (not as quite as loud, but it's definitely there). For me this was a less expensive and acceptable alternative to the cone filter approach.
I also decommissioned the pre-heater manifold on top of the throat of the aluminum collector box on top of the intake plenums.
I added a K&N panel filter too, painted everything black and when the box is assembled and the radiator hose and headlight cable are placed into position, the connector is virtually invisible. It should make it through the smog visual inspection with no problem. I totally agree about the performance difference, the growl and disabling the pre-heater is a great idea!
