I'll check on the holes at the weekend.
Pretty sure there was no limit to seat travel
Again I'll check at the weekend.
AndyO...
Redline wrote:Finally getting around to installing mine (the reclining Nurburgring models). The fore-aft bolt spacing is 270mm, so less than on the original sliders, as you said. Just curious if you used the original front hole, or the original back hole, to go with the new 8 mm hole you drilled. Also, did it limit the seat travel at all? I've been trying to get my head around the best way to do it, as it seems the extra screw will interfere with the little roller inside the rail.
