fixed a couple broken studs:
undercoated the areas behind the front fenders:
cut out the old and welded in the corner piece that hold the switch to run the early engine bay lights:
seam sealed the wiper cowl area:
drilled the holes and mounted the bracket for the earlier style hood prop using the pattern i made when i removed it from the other car:
