Here's the issues I'm experiencing, hope you guys can give me some advice on what could be the problem? I have the rear axle on jackstands as told to do to open the compensator.
Problems:
1) New bleed screws from IAP don't seem to be correct as they won't thread all the way in and when tightening them i can't get them to close the fluid off. I did check the part # with their website and it matches with what the sent me. The bag says Fiat, AR 164. They do look different them the original ones I took off.
2) I'm getting fluid to the rear passanger side caliper(furthest from the MC but none to the drivers side caliper.
3) I've tried the old bleed screw from the left rear caliper on the right rear caliper but I can't get it to close either and fluid still drips out.
4) How far is the bleed screw suppose to go as I can still see about 2-3 threads sticking out, its the furthest I can turn it?
Things I've changed:
New pads front and rear, 5 new rubber hoses, changed one metal brake line, rebuilt front calipers, rear calipers looked to be in good shape so I didn't rebuild them. I did screw the pistons in, and aligned the inscribed line which is on the piston face as I so in a thread, if I did that some how wrong would that stop the bleed screw from tightening down?
I'm using one of those cheap bleed bottles which attaches to the caliper bleed screw.
