the lower controlarm is bolted to the body with 2 bolts. One bolt is fixed to the body, the other one ( most to the front of the car) is loose, a 8 cm bolt with a "rounded head". Should that bolt be welded or is there another way to put the required torque on that when refitting the lower controlarm ?
thanks in advance, Geert.
