In the middle of a brake rebuilt. Need to buy them locally. Do you guys know the specs or a common retailer (PePBoys, Advance, ZutoZone...) that carries somethign similar?
Its for a 76 and it has two fluid reservoirs and two hoses.
Thanks.
Brake reservoir to master hose. Where to find locally?
Re: Brake reservoir to master hose. Where to find locally?
Check your local VW shop.
Trey
Thanks.
A couple of people told me the same thing. Also, I found out from the Midwest Fiat page that pre-76 use 5mm ID and 77-up are 7mm.
Update: Found a VW vendor in the Atlanta area that sells it for $7/foot. They sell the blue German line which is 7mm ID and 2mm thickness. Iternational Auto Services in Forest Park, GA.
