Abarth bumpers on the CHEAP
- SLOSpider
Ok so I ordered some rubber bumpers off another car to see about fitment and here is what I got so far:
They fit pretty good and even better if I wanted to mount them closer like another member is doing. I just stuck them in the exsisting holes with some washers to check them out. They can be lowered a bit but would need to drill new holes. The bottom has a little bit of a gap but easily filled with black silicone, weatherstipping, rubber, what every suites your fancy. I have another set for the rear but have not removed the bumper yet.
The right side is off due to some body damage there I need to address. I may end up using them as untill I can figure out my split front and rear bumper mock up. For $60.00 its WAY cheaper then the alternative!
Oh whats that? what are they off of???? Do I dare tell, I know that someone already knows as its where I got the idea to try them out. So post up your guesses...
1975 124 Spider
1989 Chevy k5 Blazer
1967 GT Mustang Fastback
Re: Abarth bumpers on the CHEAP
Someone else's Spider? They do fit well!
1972 124 Spider (Don)
1971 124 Spider (Juan)
1986 Bertone X19 (Blue)
1978 124 Spider Lemons racer
1974 X19 SCCA racer (Paul)
- ga.spyder
Mid 70's Triumph Spitfire ??
Craig Nelson
Fling It Around Turns !
- Your car is a: 1970 SPIDER AND A 1976 SPIDER
Spill the beans already
- SLOSpider
Ok Ok, so impatiencent They are off a 1973-1974 Porsche 914 rear bumper guards #914-605-063-10 for the left and the right Ill have to check but from VW parts experience its probably 914-605-064-10. I have a set of the fronts but dont fit as nice as the rears. They may work better for the rear but I have 3/4 tank of gas and did not want to finish taking out the tank yet.
I need to get the shock towers fixed before I can drive her though. Im really wanting to make a split front crome bumper for her so I will probably end up selling these as soon as I get that squared away.
If you are looking for some I ended up buying the rear bumper but had him ship me just the guards.
Here is one like it you can keep your eyes peeled for:
http://cgi.ebay.com/ebaymotors/1970-197 ... _500wt_956
1975 124 Spider
- SLOSpider
Found some new RIGHT ones $55.00
http://www.stuttswap.com/stuttswap/bbarbin/bbar914.html
And this place shows them for $80.00 each, if they have them?
http://stores.ebay.com/Porsche-Parts-An ... pping.html
1975 124 Spider
- ITA124
Pros
1) They're cheaper than the after market abarth blocks
2) They're probably made of a denser rubber than the after market items
3) They cover the whole hole left from the removal of the shock tubes
Cons
1) Mounting the blocks without drilling holes in the panels. You don't want these rattling loose and falling off. Looks as though you can weld up a 'T' section between the mounting studs and to the existing bumper shock mounts
2) They stick out so far, they look like a pair of erect nipples . Appropriate for the cooler climates.
Question
1) Can they be re-profiled? ie, is the rubber material at least 1/2 way down.
Cons
Question
Paul
Fiat 124 Spider (Big Red Car. So my son tells me)
Toyota Corolla AE86 (Fiat as a daily driver? Not)
Fiat 128 Rally (Why did I sell this car?)
Fiat 124 AC (An iron ore waffle shaped like a 124. Donated to Sims)
Fiat 128 SL (First fiat)
- SLOSpider
I dont know if they can be re profiled but I would assume so as they seem to be solid rubber.....I just changed the cars name from Sophie to Madonna ... much easier!
1975 124 Spider
- wachuko
- Contact:
SLOSpider wrote:I dont know if they can be re profiled but I would assume so as they seem to be solid rubber.....I just changed the cars name from Sophie to Madonna ... much easier!
Drive Safe!
Wachuko
1967 912 Progress Thread
2012 BMW X5 xDrive35d
2015 FIAT Abarth
Wachuko
2015 FIAT Abarth
Did you get the pic's I sent the second time SLospider?
Not to bad, thanks for the alternate idea. I just removed the monstrous bumpers off my car.
- SLOSpider
Thinking about reshaping these. Anyone have any experience on cutting and shaping rubber?
1975 124 Spider
That's funny, I was thinking the same thing.ITA124 wrote: 2) They stick out so far, they look like a pair of erect nipples . Appropriate for the cooler climates.
