P.S - found out both upper ball joints where bad so had to replace them also. Wasn't too bad, little heat and air chisel cut those rivets right out. Hardest part was knocking the ball joint out of knuckle.
http://www.belletireadvantage.com/Coupo ... /main.aspx
