window frame
window frame
the window frame that is built into the top it has obviously 3 sides for the glass windows. what im looking for is the metal pieces that surround it. does anyone know where to get these pieces? mine are rusted and because they are so thin they just aren't healthy anymore. if i could get those pieces (or make them) i wouldn't need to buy another top cause the frame is in good condition.
Re: window frame
basically the piece circled (squared) but also the whole surround of the glass part i'd like to replace.
Re: window frame
What year is that from? I have two or three cars. I probably have the whole item including the glass. I'm not sure what part it is you really need. Is it the rear side window? Driver side? Where are you located?
Re: window frame
my car is a 1981 cs0
the top if its on the car the piece im looking for is the piece that actually touches the body underneath the window. its essentially the whole triangular window frame. if you can picture that part? i'd like the whole top but im looking for a slightly cheaper alternative to buying a complete frame.
i am in East Tennessee.
Re: window frame
a few more pictures to give you a look at what im pointing at here.. its the frame around that glass window.
Re: window frame
I just looked at mine and they actually need media blasted too. Another job added to the list. I have to see what shape they are in after blasting to see if they're worth selling. I'll need some time. If someone else has one. Go for it. IF not I'll get back to you in a week or two.
Re: window frame
yeh im gunna need both sides as they are both rusted through cause they are so thin.
obviously if i can find a good price one the whole setup i'd be happy to do that cause i will have to build the pieces otherwise.
so does anyone have any idea where to purchase a top skeleton?
