1980 fi spider black smoke
1980 2000 spider,i have been restoring this car for all most a year.just got the body and paint all done and the car wont run.Tack wont work,the car runs good untill it worms up,then it starts running very rough with black smoke. its loading up! I have replaced the lambda sensor, cold start with switch, a reman air flow sensor, fuel reg, i have 34psi, throttle plate switch and set, auxiliary air reg. Im starting to thank its in the wiring after replacing parts and looking at the wire it has a lot of tape on it. I have a big blue wire coming out of the firewall by the coil it has two wires in it I cant find it in the wire dig anywere it comes out of the ECU can some one tell me where it goes,and allso why its getting to much gas.
I looked up the temp sender resistance, with a hot engine the spec is 260 to 400 ohms.
Here's a link to the FI wiring diagram. I don't see a blue wire to the coil.
http://www.allisonsautomotive.com/1981s ... %20009.jpg
i grounded the #5 and it did make it run very good.at a nice idel,replaced the temp sender and it did stop the black smoking.
One more thing on the tac i have GROUND a NEG and POST.
im getting 12.5 from the POST and at idel im getting 3.5 on the NEG and it goes up with RPM IS THE Tac bad?
THANKS ALOT FOR YOUR HELP
here is the tach troubleshooting info-
Connect red voltmeter lead to yellow/black wire at tach. Connect black voltmeter lead to ground. Turn ign on.
Meter should read 8 to 12 volts. If meter does not read voltage, repair yellow/black wire from tach to connector for water temp gauge. If meter reads 8 to 12 volts connect red meter lead to brown wire at tach. Connect black lead to ground. Start engine and increase, then decrease engine speed. Meter should increase and decrease too. If meter reacts to engine speed changes, replace tach. If meter does not react, then repair brown wire from coil.
