What is wrong with your original cross member?
The original had three cracks around the bolt that holds the lower A arm to the cross member. There was also a crack on the opposite side near the motor mount. Also, the nut that is welded to the cross member where it bolts horizontally to the frame was broken off on the passenger side of the car. The cracks in the lower member were REALLY bad and I was extremely fortunate to have found them when I did. I'm sure that it would have snapped when I hit the next bump in the road. There was less than 1/4 inch of metal left holding the pivot pin to the front side of the cross member. It was a major accident waiting to happen. The metal around the head end of the lower A arm bolt was completely snapped through on both sides of the bolt. There was nothing holding it together.
For the second time, I attempted to fit the "refurbished" cross member to my car. Just as before, the plate made it impossible to fit between the frame. It was exactly 1/4 inch too wide which was the exact thickness of the metal plate.
I got ticked off about it and decided to cut the *#$&*& plate off. Upon grinding off the welds, it was blatantly obvious to me that it was added at a later date by someone. There was absolutely no reason for that plate to be there.
I bought the refurbished cross member from Vick's Auto Sports. Jerry Phillips was extremely responsive to my multitude of inquiries and dialoged with me throughout the process. Unfortunately, I was going to have to pay the $42 to send it back to him for a refund or replacement. That would have brought the non-refundable shipping costs to about $60, but he gladly offered to replace it less the cost of shipping. He remained convinced that the plate metal that was welded on was from the factory. I still beg to differ.
With the plate cut off, the cross member fit perfectly and bolted right in with no problems. The car is back together excluding the shock absorbers which needed to be replaced since they were the original ones that came on the car in 1979....a bit stiff to say the least.
I'm really glad to have it back together. Hopefully, I can get the shocks shipped quickly. We're expected to have 70 degree weather this week! Of course, I still will need to get the car realigned before driving it any distance.
John G.
1977 Spider (Sold 2017)
1979 Spider (Sold 2015)
1980 Spider (Sold in 2013)
1981 Spider (Sold in 1985)
