Weird fiat
- kilrwail
Re: Weird fiat
Just for amusement, get the serial number off it. Mine is 124CS1 0139358. With those later tail lights, this one should be a higher number, I'd think.
Peter Brownhill
1977 Porsche 911S - track car
2022 Ram 4 x 4 - hauler
Peter Brownhill
- red107
- Contact:
Re: Weird fiat
Here are the pics of the car
1981 Fiat Spider 2000
2018 Jeep Wrangler JLU
- red107
- Contact:
Re: Weird fiat
His is 124CS1 0139230. Pretty damn closekilrwail wrote:Just for amusement, get the serial number off it. Mine is 124CS1 0139358. With those later tail lights, this one should be a higher number, I'd think.
- wachuko
- Contact:
Re: Weird fiat
'05 tag! That thing has not be run in 5 years? Gas in tank must be varnish by now.
I am guessing that all fluids need to be replaced, looking at the photos I would also check (and replace) the differential oil/fluid, as well as the transmission oil.
Car looks to be in one piece. Glad to see they are bringing it back to life!
Drive Safe!
Wachuko
1967 912 Progress Thread
2012 BMW X5 xDrive35d
2015 FIAT Abarth
Wachuko
2015 FIAT Abarth
- red107
- Contact:
Re: Weird fiat
wachuko wrote:'05 tag! That thing has not be run in 5 years? Gas in tank must be varnish by now.
Before I started it up I checked the oil levels. It was amazingly clean. It will be changed along with the other fluids. Dropping the tranny this weekend. changing the clutch, clutch cable, pressure plate, and bearing. They parked it on 05 when the tranny wouldn't change gears. Also somebody did a hack job on the ignition switch wiring. For the cost of 300.00 The car will be back on the road. There is only one bad area on the car. where the A/C unit was. rusted the passenger side floor pan pretty bad. They were going to junk it a few years ago and a neighbor talked them out of it. Thank go. got to keep these cars on the road.
- kilrwail
Re: Weird fiat
Strange - maybe they sent cars with the older taillights to Canada, even though my serial number is higher. I have U.S.A. stickers under the hood, but the odo is in kilometres, so it was orginally shipped to Canada and I bought it new in Montreal. Strange company.red107 wrote:His is 124CS1 0139230. Pretty damn closekilrwail wrote:Just for amusement, get the serial number off it. Mine is 124CS1 0139358. With those later tail lights, this one should be a higher number, I'd think.
Peter Brownhill
Peter Brownhill
- ga.spyder
Re: Weird fiat
Its a shame they evr went to the newer tail lights.The ones on my 77(old style) are way more attractive than the larger ones on my 82.
Craig
Craig
Craig Nelson
Fling It Around Turns !
- wachuko
- Contact:
Re: Weird fiat
Red, is it back on the road?
Drive Safe!
Wachuko
2015 FIAT Abarth
Wachuko
2015 FIAT Abarth
- red107
- Contact:
Re: Weird fiat
Not yet, The car is running, got all the electrical worked out. Just need to get the transmission issues worked out. I have it all back together. just need to put in a new clutch cable in get the drive line put back together.wachuko wrote:Red, is it back on the road?
