Not too far from finishing by Spidy, have only the center consul to fit and wire up the radio etc. I had done most of the work, but had left some wires dangling, but separated so as not to short out. While doing some other touch up I went to the fridge for a cleansing ale. Daughter's cat had decided to have a look inside car......When returned cat was heading for the hills and smoke was pouring out of the dash........I saved the day but lost a meter or so of insulation. Another few hours of work not planned for. Cat has not even done training in the art of Italian wiring......
Baz
aaaaargh !
Re: aaaaargh !
haha ouch, sorry to hear that. I typically disconnect the battery when working with electrical
Re: aaaaargh !
Look on the bright side. You may have found the one and only way to keep your cat off your car! Let me know if it works, I'll gladly throw my cat on some naked wires and buzz her a bit if it keeps her off the paint.
1972 124 Spider (Don)
1971 124 Spider (Juan)
1986 Bertone X19 (Blue)
1978 124 Spider Lemons racer
1974 X19 SCCA racer (Paul)
- kmac33
- Your car is a: 1974 Spider
Re: aaaaargh !
Sounds to me like your cat is actually trained in working on Lucas wiring systems! Lots of smoke and burnt insulation are signs of a Lucas system functioning at factory specs
Kevin McMullen
1980 Fiat Spider
2013 Subaru WRX
1980 Fiat Spider
2013 Subaru WRX
Re: aaaaargh !
I think your cat may be trying to kill you!
You might want to read this.
http://www.catswhothrowupgrass.com/kill.php
Re: aaaaargh !
ahhh.... that's not so bad. I have the stuff you may need:
http://www3.telus.net/bc_triumph_registry/smoke.htm
since i sold my SpitWad, i've not found a huge use for my stock.
Re: aaaaargh !
Um...I have also had a fuse block melt down with some flaming drops and smoke. Will I now need two replacement smoke kits or is flame not counted ??
I have shaved cat's tail to look like a penis.....not happy...
Baz
Baz
- Your car is a: 1981 Spider Turbo - missing the turbo
Re: aaaaargh !
Baz, Are you bringing the car to the Fiat Nationals in Gouldburn ?
http://www.fiatnationals.com
AdrianS
AdrianS
THE FLEET
2014 Abarth "SS"
2014 Abarth "SS"
Re: aaaaargh !
Ha ha, I guess that's why I'm a dog guy.Foster48x wrote:I think your cat may be trying to kill you!You might want to read this.
Trey
