So here's a question for all you forum people and maybe you can help me diagnose the problem. When I hit the ignition the starter runs a bit slow, almost like the battery is not up to snuff, mind you it starts every time, but it just seems like the juice is not there. I have a sealed battery so I took it to the local auto parts store to check it out. It is a 540 CCA battery and it reads 544 on the guy's meter, so I know the battery is good. I'm not sure of where to look next and could use your collective thoughts.
Also had a similar problem as described in the electrical forum: car wouldn't start with the parking lights on but started right up after I turned them off. Hmmmm?
