Well, I've bought it! Check out my catch
http://s215.photobucket.com/albums/cc17 ... er%202000/
It has some idle issues and the exhaust is hanging a little lower than it should, but the oil pan has nary a single ding in it, and the body is in good shape. Transmission is crisp and doesn't slip out of gear, and the clutch is good.
The top is...alright, it needs some work...it has some new tires on it, it has a bit of an oil leak, but I believe we found the leak area. Also the tires need to be balanced, and it still has the stock rotors from '81 on it, so those need to be replaced eventually. And all the rubber bits are from 28 years past as well. With that said, it does run strong and drive good. The paint is in awful shape, and it needs repainted...luckily it still has the color formula/code/name on the inside of the trunk.
Power windows! and the clock even works!
The guy who owned it is a great guy, its been a 3 owner car, and he knew the other 2 owners, and it sat in a garage for 10 years before he bought it and started playing with it. It's been babied all its life, and in the few years that the last owner had it, he only put about 200 miles on it. 62,304 miles on the odometer.
I think I found a winner!
