Hal
halg wrote:Here is what I have done for my front suspension. The spring and shock are QA1 for a GM application(the lightest they show) I always suspected I would have to shorten the spring. The whole assembly went in the car an hour ago and I will have to shorten the spring 1 coil to give enough adjustment. The brakes are from an 89 Honda. I fabricated the mounting bracket for the caliper(very similar to original) The rotor is larger than stock but still fits inside 13" wheels. The pads are larger also. The piston is close enough to use the original master cyl. As you can see the rotor is vented. I added stiffeners to the lower A arm and welded all joints to stregthen the shock mounting. The spring accepts the stock upper mounting bushing.
Hal
Yup I have seen that machine. Quite the work of art.halg wrote:Rob:
check out post "what's underneath" in custom, then lets talk
Hal
