aluminum dash project (help removing chrome from plastic)
htchevyii
Post by htchevyii »
Heather's Spider has a beautiful Denise built mahogany dash, but I wanted someting a little racey for this one. I'm making one out of a roadsign, (gotta make up for Cali's new taxes & I'm still waiting for my refund check). If I didn't pay $56.00 for hole saws I'd be in good shape. I need to dissassemble the gauges, (how did they get so dirty inside) and paint the center plastic before I can go further. Has anyone found a chemical that removes the "chrome" from the plastic? I spent about an hour with a razor blade and got all the loose stuff off, what a p.i.t.a. I Spent about 5 hours over a two week period getting all the crap off the tail lamp bezels, before painting them with Mike's famous wrinkle paint, but there's got to be a better way!
Trey
Tappy
Your car is a: 124 spider 2000 1979
Re: aluminum dash project (help removing chrome from plastic)
Post by Tappy »
you may use a chemical paint stripper , dont let it be on to long do , but the plastic will last longer than the paint ...
FineItalianAutomobile TechnologyImage
htchevyii
does the o/p or temp gauge go in the center?
Post by htchevyii »
Well, I finally got all the gauges cleaned and reassembled, which one goes in the center? Yes, I deleted the clock.
Trey
such a clean hand!
TulsaSpider
Post by TulsaSpider »
Wow I'd be concerned about being blinded when the sun hits that!
htchevyii
Post by htchevyii »
TulsaSpider wrote:Wow I'd be concerned about being blinded when the sun hits that!
I live in N. Cal., there isn't any sun!
Trey
pope
Post by pope »
The way you have them is correct. Gas on the left, water in the center and oil on the right.
htchevyii
Post by htchevyii »
So Cal Mark wrote:such a clean hand!
Today was a easy day, I spent it taking apart the gauges and cleaning them. I did stab my hand with a screwdriver a few times while prying off the bezels. :x
Trey
fiasco
Post by fiasco »
Trey - as far as the center bezel is concerned, I had no luck with mine. Couldn't get the old chrome and black off enough to satisfy. I made a replacement with wood for the frame, mahogany insert panels (deleted all the warning lights, but you wouldn't have to if you didn't want to), and a strip of adhesive "chrome" trim for the center section. I painted the frame with black crinkle paint. It looks pretty good with the darker mahogany I veneered the dash inserts with.
If you end up unhappy with your stock bezel, let me know and I can whip you up a frame, and you can put whatever inserts in that you want. I think your aluminum top and bottom would look great with wood in the middle, just as a little nod to tradition.
-- se
Steve Eubanks
a few puncture wounds are good for letting out the excess blood
mbouse
Post by mbouse »
as previously stated, watch what chemicals you use on plastic. i'd prefer hearing you used some 000 steel wool rather than chemicals.
don't forget to check your specific crackle paint to see if it will adhere to the plastic. you may have to precede the finish coat with some etching primer.
is it safe to presume that the ash tray is getting it's own coat of crackle? or, maybe a conversion to another use?
http://flumichigan.italiancarclub.com/T ... shtray.pdf
htchevyii
Post by htchevyii »
seubanks wrote:Trey - as far as the center bezel is concerned, I had no luck with mine. Couldn't get the old chrome and black off enough to satisfy. I made a replacement with wood for the frame, mahogany insert panels (deleted all the warning lights, but you wouldn't have to if you didn't want to), and a strip of adhesive "chrome" trim for the center section. I painted the frame with black crinkle paint. It looks pretty good with the darker mahogany I veneered the dash inserts with.
-- se
Wow, tht came out really good! I know I can salvage the bezel, I just didn't want to spend hours on it like on the tail lamp bezels. I think another hour with a razor blade might do it, but if not, I'll be in touch.
Trey
htchevyii
Post by htchevyii »
mbouse wrote:as previously stated, watch what chemicals you use on plastic. i'd prefer hearing you used some 000 steel wool rather than chemicals.
Ya, I've got lot's to do! On the '82 I cut out the ashtray grille, but left the lid, so It's now a storage tray.
Trey
mdrburchette
Post by mdrburchette »
Trey, do you have a dremel? Maybe one of those little scotch brite discs on the dremel will take the rest of the chrome off your bezel. Are you painting the bezel when you're done?
1972 124 Spider (Don)
1971 124 Spider (Juan)
1986 Bertone X19 (Blue)
1978 124 Spider Lemons racer
1974 X19 SCCA racer (Paul)
htchevyii
Post by htchevyii »
mdrburchette wrote:Trey, do you have a dremel? Maybe one of those little scotch brite discs on the dremel will take the rest of the chrome off your bezel. Are you painting the bezel when you're done?
Ya, I figured I'd paint it with Mike's crinkle paint. :wink:
Trey
