My Dash/Console Upgrad Pics
fiasco
Post by fiasco »
Just wanted to share some pics of my dash/console with the new covers, inserts, shorter shifter,shift boot, and stereo.
Before:
After. Dash cover from Vicks. It's a little wavy on top, but the look is greatly improved, and will certainly do just fine until I have enough cash to do a new reproduction dash. New dash inserts are plywood with mahogany veneer and a bunch of coats of poly. The center insert is custom. After fitting the dash cover and my new inserts, my old, scratched, flaky-chrome center insert piece wouldn't fit, so I fabbed one out of wood, veneer, a little black krinkle paint and some chrome trim tape. Not stock looking, but does the job. Oh, and yes, I deleted all six of the warning lights, and the dimmer dial.
New mahogany steering wheel. Yes, I get a little sun glare off the chrome at certain times of day, but other than the temporary blindness, it's totally worth it.
Center console with new cover and new wood inserts. Upper insert has two 2" tweeters that are connected as the rear speakers. The shifter is the world renowned Michigan Shorter Shifter from Mike Bouse (if you don't have one, you must buy one right now - seriously), with a new boot. Veneered the ash-trays too.
Steve Eubanks
kristoj
Your car is a: 1982 Fiat Spider 2000 Turbo
Re: My Dash/Console Upgrad Pics
Post by kristoj »
Wow, what an improvement. Looks great!
John
'82 Fiat Spider Turbo
'56 Abarth 750 GT Corsa MM
'59 Lancia Appia GTE Zagato
'70 Moretti Sportiva S2
'12 Abarth 500
'59 MV Agusta 250 Raid
Pictures of my baby!
racydave
Post by racydave »
Good job, very clean!
TulsaSpider
Post by TulsaSpider »
Sweet! looks great! So you just glued veneer onto the plywood and then drilled the holes? I'd get a new rubber for my clutch pedal if I were you! That can be dangerous!
ga.spyder
Post by ga.spyder »
Nice work,Steve. That really has freshened up the look of the car.My pedal pads were worn out and I opted for MOMO pedal covers. I like the look and feel of them,and they are inexpensive.
Craig
Craig Nelson
Fling It Around Turns !
rlux4
Post by rlux4 »
I'm looking forward to seeing your new and improved Spider at the coming run.
Ron
Ron Luxmore
rlux2n2@gmail.com
fiasco
Post by fiasco »
Thanks all.
Tulsa - I used the old inserts as templates and cut new ones from plywood, and drilled the holes for gauges. Then painted the wood to seal it up and make the edges black. Then put on the veneer with contact cement (like the stuff you put on countertop veneers with), and trimmed the veneer to match the plywood. Finished off with lots of poly.
Looking forward to getting some opinions and comparing to some other cars at the run on the first, as well as meeting a bunch of you guys.
-- se
Steve Eubanks
WarbirdAL
Your car is a: 2 1977 124 Spiders 1969 124 Coupe
Post by WarbirdAL »
how does that short shifter feel? and was it difficult to install? any special tools needed etc
thanks for the pics, looks nice
ga.spyder
Post by ga.spyder »
If you look in the 'Fiat Related' forum ,I did a road test on the shorter shifter.I like the feel of it,and the shifts are much more positive.It isnt too short at all,only an allen wrench needed for the install.Great,inexpensive upgrade.
Craig
Craig Nelson
fiasco
Post by fiasco »
Here's a link to Craig's review:
http://www.fiatspider.com:16080/f08/vie ... f=3&t=4740
It's a great write up, and I second all his conclusions. Very easy installation, much improved feel and look. I would recommend this as a must-have to any Spider owner.
-- se
Steve Eubanks
mbouse
Post by mbouse »
Steve,
Very nice refurbishing job... i especially like the red stitching in the shifter boot. and, of course, any use of krinkle paint is a welcome sound!!
