Work in progress-Gauges
I have replaced the original gauges with ultralite gauges.I started off replacing the original wiring harness with a 8 circuit painless wiring kit.After many hours of tracking wires and testing circuits I am 75% done with the swap.I still need to fabricate some sort of speedo cable and track down a problem in the charging circuit.I'll post some better pics at a later date.Thanks for everyones advice.Ray
Re: Work in progress-Gauges
I made the dash piece out of plexiglass(a couple of them)then covered it with black leather-like material.The center section and dash are from a 1983.On the center section I had to weld up some holes,Then covered that,put gauges in, and covered the glove box door.I hope to drive it by spring,of course I said that last fall Ray
- danaspider
- Your car is a: 1979 Spider 2000 79 vw bus
Really like the big date on the radio!!!! Starting to look like the old MGB I once had.
Luck Dana
79 Spider 2000
carb
It all about the romace of the car and owner
79 Spider 2000
carb
I hope you have her drivin soon, we can meet-up on the Ohio river in the spring!
Sounds great!looking forward to meeting fellow spider owners on the road.
Ray
Ray
ray,
looks good, white faced gauges against the black dash. very nice...
suggestion, go get some of those 45 degree angle sleeves to turn the gauges in the center of the dash console toward the driver for better visibility.
i got some from Summit and i really like them for the gauges i put in place of the rheostats
mbouse wrote:ray,
Pictures please!
-Ryan
