It has been a couple of years since I have been around FS.com as I got distracted by an old Jaguar ('78 XJ6).
The FIAT has been safely tucked away and it is time for some winter maintenance and a chance to correct all those little things that are never quite right on a rolling project car.
By way of introduction, I will offer some perspective on how I approach work on this car.
Concept - It is a science-fair-project/performance-driving machine. I have owned the car for at least 15 years and it is extensively modified.
- 15" Wheels - Big Brakes - Tires - Sway cars - Springs - Shocks
Aesthetically - I am drawn to what I imagine and rogueish Italian James Bond would have driven in the late sixties. Recent picture below, somewhere on this site must be an older picture but I cannot find it.
- Early bumper conversion - BMW Fijord Blue paint - hood and trunk badge delete - door mirror delete - leather Del-Sol seats - roll bar - sound deadening - too many small changes to remember
Under the hood - Fire-breathing monster with inspiration from the tuner crowd and particularly turbo Miata builds.
- Lancia 8V Turbo and manifold - Lanica Dedra intake manifold - intercooler - custom injection (Megasquirt) - aluminum rad - Coil-on-plug ignition - many little things to make all this work
https://lh3.googleusercontent.com/pw/AD ... authuser=0
As we sit now in the garage, hood off, and ready to work
The car has been in this mechanical configuration for almost 10 years. It is great fun to drive although it has been temperamental lately. The worst symptom is occasionally dying for no obvious reason and then magically restarting when it feels like it. My best guess is that the issue relates to a combination of my bad wiring, an old DIY ECU, and 10 years of Frankenstein-like modifications undertaken because I watched one too many YouTube shows.
On to our current event. As I mentioned, I have a list of items to address and wanted a chronicle and some advice from the team as I progress.
Megasquirt
Issues - The auto-tune is no longer working, Firmware updates fail, and sporadic failures.
Items to address
- Dissamble ECU, clean board, re-install firmware, bench test
- Review and update circuit board modifications to meet modern specs for running Coil-on-Plug
- Remove and rebuild the wiring harness to eliminate splices and low-quality connectors
- Add boost solenoid and wiring to allow for programable boost control
- Instal dedicated MS fuse box in the engine bay as per MS manual best practices
- Add fused fuel pump power wire from MS fuse box directly to pump to abandon original chassis pump power wire.
- Remove idle air control as it leaks boost and is a PIA
Engine
Issues - some oil in the coolant leads me to think I did not get a good seal when I installed my last head gasket. Some annoying oil leaks
Items to addres
- Install new head gasket
- install new turbo oil supply line
- Re-seal oil manifold on oil-filter housing. This screws into the original oil pressure sender and provides multiple ports for turbo oil supply, oil temp gauge, oil pressure gauge, and original oil light.
- Check turbo oil drain pick-up on oil pan for leaks (again), possibly remove pan (again), try another amateur weld (again) to seal it up and stop the oil weeping.
Other
- Eliminate electric exhaust cut-out that is slow to react and never seals well. permanent exhaust leak.
- Explore some kind of performance exhaust
I hope to get one or two evenings a week to putter around on this and have it ready for spring driving.
Feel free to chime in with any recent modifications or customizations that you think may be fitting. Is there some way to mount FIAT 500 rear brakes now? I am out of the loop....
Kind regards,
Jordan
