Plan B: new radiator,...but then there's those bigger, highly efficient fans!
Anyway,...my car is auto tranny, so my choices were limited for the radiator. Bought my 14" fan from the same vender after calling to ask about fit. I was told that both the radiator and fan would fit just fine,...
Well, first the fan did NOT bolt up to the radiator - it is expected to be 'zip-tied', through the cooling fins, to the rear of the radiator. Vender told me that this method is "state of the art",...and I said "B.S.". I don't care if it is, I mounted my new fan properly, by simply fab'ing a short, straight aluminum bracket for the Spiders' 'third' fan mounting point:
![Image](https://i.imgur.com/FO3Tsjg.jpg)
The fans' mounting holes on the passengers' side are too close together to bolt into the nuts welded into the new radiators' mounting tabs, but new holes can be drilled into the new radiators' tabs to mount the right side of the fan (no pic, since there's nothing unusual to see - looks like a factory install,...except that the fan is HUGE!).
And, of course, the radiator does not just bolt in either! The mounting holes are about 1/2" too close to fit properly. But they can sure be "wallered out" to accommodate the radiator bushing and mount to the factory stud as designed.
Nice brass radiator, and very nice 14" e-fan - I like 'em! But I wish that I had been prepared for a custom install, rather than being told that it would fit,...
At least I'm able to alert future buyers.
Motor On!
Todd.
