wetminkey, nice work and nice report.
In the last picture, I'm having hard time spotting your repair. Maybe I do not understand where it is.
Crossmember studs/frame reinforcement
Re: Crossmember studs/frame reinforcement
Nicely hidden, huh?!
Check the top of the framerails (either side) just above the crossmember attachment,...silver round-edged plates.
Vertical bolts are welded into each plate, in a "U" bolt fashion, and Brady ground the heads to hide the alteration. He primed them black, as I'd asked, but they disguise the plate and the tops of the ~5 1/2" bolts so well, that I felt I should hide things with the silver paint.
Upper plate is probably ~1/8" plate steel, lower plate (to repair the cutout bottom of the rail and old studs) may be the same thickness as the welded through-bolt pieces of pipe - 8 gauge steel. Bolts are grade 8, and I measured the crossmember holes at 7/16". All four bolts that hold the crossmember have 'Nyloc' locknuts in addition to regular nuts, flat washers, and a lock-washer.
I sure hope that this helps the next owner that has to fix their Spider's crossmember attachment to the unibody framerail!
Merry Christmas, all!
1988 Mazda RX-7
1979 Fiat Spider 2000
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
This is the best pic that I could get from under the car - crossmember 'through bolts' that travel through the entire framerail and crossmember both. They are welded to their upper plate in a "U" bolt shaped assembly, one for each side.
The "U" shaped plate + two bolt assembly can be unbolted and removed from each side,...they are not welded in.
Super strong.
Todd.
Super strong.
Todd.
1988 Mazda RX-7
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
