Removing Front Shocks
- Odoyle
- Your car is a: 1983 Pinafarina Spider
I'm trying to remove the front KYB shocks that the PO put in and replace them with fresh KYBs and I'm encounting some trouble. Iv removed the disc brake assembly to where just the spindle, ball joints, upper and lower arms, spring, and shocks are left. Iv disconnected the shocks from the lower control arm and have put a jack under one of the springs to compress it. I'm using a large adjustable wrench to try to unsrew the upper portion of the shock but I feel like iv been spinning the thing for ages and can't tell if it's actually loosening. I am going lefty loosey and I know I'm not just spinning the bottom of the shock. Any feedback would be appreciated.
Re: Removing Front Shocks
shocks have a flat at the top of the thread. You can hold the shock there so you can loosen it.
- Odoyle
Post by azruss on Thu Jan 15, 2015 12:12 pm
Can u elaborate
Can u elaborate
- Odoyle
Baltobernie, thank you your photo was very helpful. I'm not sure what year your 124 is but it looks like Fiat was feeling nice that year because the shock mounts in my 83' Pininfarina are brutally hard to get to, spent a good part of my afternoon removing a single shock on the front right corner of the car. Tomorrow I will remove the front left shock and by the looks of it, it will be just as difficult if not harder. Anyone else encounter this on their 2000cc 124's?
some more advice is to use a u joint to get to the hard to reach area (top nut) and some locked pliers to prevent the shock from turning
I found the use of a gear-wrench made things a lot easier.
- 124JOE
jay I hope that's not Fiona
I see a bushing that is looking quite crappy
I was trying to not say anything but a silent "boy am I happy I don't live in the road salt belt anymore".124JOE wrote:jay I hope that's not Fiona
Keep forgetting how brutal that stuff is on your vehicles.
I will confess that there were times that in frustration over a salt galled shock I have put a deep 1/2" drive impact socket on a long extension and just busted the top stud off prying it side to side.
all taken care of years ago
by the looks of it when I got her, she had been neglected. no winter driving since
http://fiatspider.com/f08/viewtopic.php ... hilit=fall
- 124JOE
ya mine also.NO SALT
its covered and stored in my garage
- moss1972
To this guy...THANK YOU! 4uall, I used this technique on my Jeep by vice-gripping the piston shaft, but could not get access to that shaft on the Fiat. Your image of the vice grips on the shock tube saved my arse. I didn't think the shock tube would halt rotation.4uall wrote:some more advice is to use a u joint to get to the hard to reach area (top nut) and some locked pliers to prevent the shock from turning![]()
The use of the vice grips on the shock tube as well as a 9/16" (14mm) ratcheting closed end wrench and the fronts were off in 12 minutes.
Steve
MA/NH
1979 Spider 2000
MA/NH
1979 Spider 2000
The shocks are easy compared to the springs. Just upgraded to 15"wheels and lowering springs. Had to disconnect the top A arm at the frame and give the brake line some freedom by removing the clip in addition to compressing the spring.
