(Obviously I am NOT happy with this, the Compu was a lot of money, they fail at a high rate, and there is no service available).
At any rate:
The system looks like this:
I see how the control module goes, the vac hose, the spark plug and primary coil wire, the control module cable, 12VDC in from the IGN "ON/RUN" to "B", how the mounting plate goes, plenty of thermally conductive Gumpcukrus under the control module, "B" of cable (RED) passes through Control Module to "B" of coil, BLK to the other post, no problem, but where does the Condenser go?
First question: The thing I can't remember is where the Condenser hooks up? Can't find anything in the manual.
Second Question: The only external input to this system is the 12VDC to Coil "B" is that correct? Everything else I have shown in the picture. I can easily restore that if I am correct in this assumption.
It does passes all the electrical tests that are in the manual. Here are the various pages, they may be of help to others. THIS IS FOR '79 ON.
