71 fiat??
- Your car is a: 1979 124 spider 2000
71 fiat??
i bought a titled 71 fiat.. but not 100% sure if it is that year.. anyway to tell for sure.. first fiat.. thanks for info https://www.facebook.com/photo.php?fbid ... =3&theater
- Daddio
- Patron 2019
- Your car is a: 72 124 Coupe 2L project
Re: 71 fiat??
Welcome to the obsession!
2-liter engines started in 1979; the bumpers are wrong for '71 also. Could it be an '81?
the serial number will tell you much about the car with just a little research.
Jeff Aurand
Portland, OR
'72 124 Sport Coupe
'86 Bertone X "Anna"
'70 Volvo 145 "Edna", since 1989
'87 Maserati Biturbo Spyder 2800i
Portland, OR
'72 124 Sport Coupe
- Patron 2021
Re: 71 fiat??
Not a 71, look if there is a plaugue on the drivers side door above the latch. #1 just a little research will tell everything.
- joelittel
Re: 71 fiat??
The badge on the back does not say Fuel Injection, so I’m guessing you have an early ‘80 with carbs.
But like others have said, the serial number will tell you everything.
Re: 71 fiat??
The wheels are from a 79.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
Re: 71 fiat??
thanks everyone.. just learning about it... used to have a classic mini..so this is new to me..
Re: 71 fiat??
well looked at the attatched vin plate.. listed on it as a 128.. well i know it wasn't that found the stamped number in the body above.. all the vin look ups require a 17 digit number.. is there a place to check for sure? i did do some research on that it might be a 1979 due to the number order and that it's a 124 2000 for sure..
- joelittel
Re: 71 fiat??
A few years back a guy named Bradley Artigue wrote a book called “Maintaining the Italian Roadster.” If I recall correctly the first chapter was about how to correctly identify your car. I’m 99% sure I have that book at home (meaning it is not on loan to anyone at the moment).
As soon as practical I’ll take a look at what it says and report back.
- Your car is a: 69 AS Spider
Re: 71 fiat??
Hi there,
the worldwide spider registry can help!
https://www.fiatspider.de/der-spider/registry
(although we have actually published only a partial list of the complete registry)
The "2000" badge in the back tells us, that you have a 79 spider. Your serial number must begin with 124CS201xxxxx
With the complete serialnumber it is possible, to identify the month of production. But this info is also stamped in on a plastic badge at drivers side door.
So, whats your serialnumber?
Bye, Ralf
Bye, Ralf
69 AS Spider
the Worldwide Spider Register
Be part of it and register your car(s). Starting point here:
https://www.fiatspider.de/worldwide-spider-register
- Daddio
- Patron 2019
Re: 71 fiat??
You may also want to join mirafiori.com, they have an excellent library for members, and the forum is quite active. I'm in at xweb.com too, they have a front engine-rear drive section.
Jeff Aurand
Portland, OR
'72 124 Sport Coupe
Portland, OR
'72 124 Sport Coupe
