We took the Fiat our for a quick drive yesterday. What a cool feeling driving a brand new 40 year old car with a lot more get up! Awesome. Perfect power upgrade and combination with the transmission. Looking forward to range testing and finalizing programming. Here are some detail photos of as we get within a couple week of wrapping this up.....
Drives! Video coming soon.
Kerb Weight: Minus the hood and front new bumper but we are looking really good on weight... less than OEM! Front to rear is pretty good too. Tires like to scratch...
Motor Bay: A few small finish details but this is about it.
Glove Box Data Center... Controller Monitor and Battery Management System (BMS).... Provides excellent info.. 12v charge rate and system status, HV system and battery status, HV/LV system separation confirmation etc.... some valuable data for instant vehicle information.
Brake System: Completely new OEM brake system with the exception of vacuum pump and vac reservoir. Vac pump is hidden in the wheel well. Really good performance and power with easy pedal. We have yet to program the Regen.
Back End: All wired up and running. Some wire clean up and panel install and its done. 1000 watt DC/DC converter for 12v power, Smart 3.3kW Level 2 Charging works with 110/220v...
A couple small clean up items to the charge port.....
Switch Plate should be here shortly for the Forward Reverse Switch, hazard & Ped Bell....
