dual carbs for my 1608
georgeramos
Post by georgeramos »
My friend and i recently picked up a cheap bc coupe in need of restoration so while we figure out which one of us will get to it I snagged the idf 40s 13/15 set and the manifold. I am going to restore the carbs and put them on my 71. I will document the process here.
georgeramos
Re: dual carbs for my 1608
Does anyone have jetting specs for the Euro IDFs that sat on the 1608?
Id like to either re jet anew or at least understand where Im at in relation...
sptcoupe
Your car is a: 1972 124 Sport Coupe
Post by sptcoupe »
Here you go:
32 mm venturis
4.5 aux venturis
F11 emulsion tubes
125 mains
180 airs
55 idles
80 bleed backs
55 pump jets
175 needle valves
georgeramos
Thank you!
michaelger
Patron 2023
Patron 2023
Your car is a: 1971 Fiat Spider
Post by michaelger »
Hi George, I have a question on this. I also have a 71 spider and just found an IDF/Waffle/Turtleback setup. My car has the flat hood. Did you have any hood clearance issues when you installed the carbs? Did you use a Turtleback Air Filter assembly? Thanks for any advice you could give!
Mike
georgeramos
Hi Mike, I haven't done it yet...nor do I have a turtleback. I would be using individual cleaners likely the oval ones AR sells with the foam filter. I gave them to my friend to restore for me and he hasn't gotten to it yet...
seabeelt
Patron 2019
Patron 2019
Post by seabeelt »
The flat hood won’t work with the turtle back air cleaner. You need the small bump hood for that little bit of extra clearance. Ask me how I know.
I have dual IDFs with the standard lunch box air cleaners and I can see on the underside of the flat hood where the top of the air cleaner rubs the paint
Since the turtle back is much wider and sits at a slight angle the hood won’t close with it in place.
I think someone mentioned using Volvo motor mounts to drop the engine a bit but you need to be mindful of the oil pan and crossmember clearance
michaelger
Patron 2023
Patron 2023
Thanks a lot for the reply. I will get a small bump hood and let you know how it worked out!
