Cutting Springs
SLOSpider
Re: Cutting Springs
Post by SLOSpider »
What wheels are those and size of rims and tires? Did you buy them or were they already on the car? Looks good!
1975 124 Spider
1989 Chevy k5 Blazer
1967 GT Mustang Fastback
meangreenspider
Your car is a: 1982 Fiat Spider 2000
Re: Cutting Springs
Post by meangreenspider »
SLOSpider wrote:What wheels are those and size of rims and tires? Did you buy them or were they already on the car? Looks good!
I actually found the wheels and adapters on ebay last fall. They are 15x9 Mora wheels with 195/ 50 tires. The adapters convert from the stock 98mm to 108mm. I have not been able to find an extra wheel for a spare. There is some Italian writing on the back of the wheels but that is all I know. They are not the ideal wheels that I would choose but bought for $350 delivered to my house and I think that was a steal.
I am looking for a spare wheel if anyone has one they would want to sell.
more photos if you want to look
http://s821.photobucket.com/albums/zz14 ... %20Spider/
wikkid
Re: Cutting Springs
Post by wikkid »
Continuing an older thread:
Having read all 11 pages here, I am looking at lowering my '84. Here are my thoughts so far - please chime in with comments and/or criticism:
I am going from stock to bumperless, which will raise the car even further before I cut springs.
1. I will measure clearance at rubber stops before starting;
2. I will take the bumpers off, which will raise the car up more;
3. I will start with 2 coils off front, one in rear, and check the "look" as well as the difference in clearance height at the rubber stops.
4. I will check angle of lower control arms, to be sure they are level, or not pointing upwards going toward the wheels.
5. Adjust further, little by little, if required/desired.
I do wish the original images were still on the early pages of the thread, where the OP asked if he should cut at point A or B. Now, no one has any idea of where those points are, and yet several later postings refer to them.
azygoustoyou
Re: Cutting Springs
Post by azygoustoyou »
If you cut too much, I have an extra set cheap.
SLOSpider
Re: Cutting Springs
Post by SLOSpider »
Id start with 1 in the front and half in the back.....but thats just me. Can always take off hard to add.
1975 124 Spider
jfrawley
Your car is a: 1982 Spider
Re: Cutting Springs
Post by jfrawley »
Wikkid,
I went back and looked for the original pics but they are long gone. As it turns out, you can cut those springs in any location because the upper spring seats in the rear rotate to any position to match how you cut them. I left the bumpers on my '82 and ended up cutting off 1.5 in the rear and 1 in the front, if that helps.
John
John Frawley
Frederick, MD
1982 Spider
http://www.dcfiats.org
Carlito
Your car is a: 78 124Spider
Re: Cutting Springs
Post by Carlito »
Hi again, guys! :-)
Still working on my '77 Fiat 124 Spider.. as time permits..
I have a simple question.
Have replaced shock w. KYBs
Front # 343 141
Rear # 343 142
However, I have also LOWERED the car (shorter springs) and now the rear shocks seem to be TOO LONG... front is OK.
Meaning that if I hoist the car up, the rear axle drops down and the springs fall off their upper perches as there is too much play now. As long as the car sits on the ground.. everything is fine.
So my question is.
Is there a shock absorber identical to the rear ( KYB # 343 142 ) but with a SORTER LIFT (about 2- 3 inches should be fine!)???
Possibly fitting another car, model, year... etc.
Thank you very much in advance!
Carlito
Re: Cutting Springs
that's one of the issues when cutting springs rather than replacing them with progressive rate springs
njspider
Your car is a: 1982 spider
Re: Cutting Springs
Post by njspider »
Somewhere along this tread FiatColumbia1 talks about cutting a coil off the rear springs without removing them from the car. Has anyone else tried this?? Sounds too good to be true. Let me know if you have done it and what were the results. Thanks
carlospena96
Your car is a: 1981 Fiat 124 spider
Re: Cutting Springs
Post by carlospena96 »
njspider wrote:Somewhere along this tread FiatColumbia1 talks about cutting a coil off the rear springs without removing them from the car. Has anyone else tried this?? Sounds too good to be true. Let me know if you have done it and what were the results. Thanks
You can do it, but it is uncomfortable to work, i decided to remove the spring from the car, it not that hard to do on the rear
