ElectricSpider wrote:DieselSpider wrote:124 volt is a little more DIY however I didn't catch whether that was DC or converted to AC.
Are the long runs of cable under the car full current or only from segments of the pack. Is there going to be shielding to protect them from damage in the final install?
I own a Leaf and a lot of work was done to prevent damage to the high current lines and prevent accidental contact.
All lines are from the contactor and rear/mid battery boxes. Per final build specs they are shielded. The bottom lines are encased in a fabricated steel sleeve. The photos per your comment show "build in progress". AC-34's are AC Induction Motors. (
http://www.hpevs.com) We don't work with DC. These AC systems are proving ideal for older conversion projects. We still have more than enough power to substantially damage drivetrains! Point in case with this car. We had to have a little fun and test the limits
Toasted the spider gear and snapped an axle clean! Nothing a little work doesn't fix! We can always tune the controller down and the AC-50 single package will be more suitable for "lower" performance.
Instant electric torque can tear things up. I was amazed at how Nissan had to beef up the electric motor mounts and front element to hold it all together. Traction control is almost a necessity especially if you want to get some decent life from the tires.
I thought at first that this was a personal project and not a commercial endevor. For those that want to try this on their own as a DYI project the Leaf would make an economical doner in the finacial grasp of many more folks.
Quite a few years back there was and electrical engineer from California that converted his Honda CVCC Hatchback and if memory serves me correctly he used a Siemens 3 phase electric motor and for a little extra kick he put in some large thyristors boosted by a frequency occilator. The thyristor capacitors allowed him to partially discharge the capacitors without wasting the complete charge in them every time he drew from them. He used all off the shelf components from the industrial electical supply house for his car to pove it could be done. I wish I had saved the info as I lost the link after a PC crash.
There are multiple options out there to fit different budgets and its all good if reasonable watch care is observed. I will say it was a erie experience the first time I drove my electric car without any AC, defroster or radio going and came to a stop llight in absolute total silence.
