Tail Light lenses removal and cleaning
spiderman1
Your car is a: 1982 Fiat Spider
Post by spiderman1 »
I wasn't sure where to post this so I went with electrical.
I need to take my tail light lenses off to change a bulb and clean them but I am afraid the will crack-I started but stopped because I was uncertain about the process.
Any advice would be much appreciated
David
Squidders
Your car is a: 1980 Fiat 124 Spider
Re: Tail Light lenses removal and cleaning
Post by Squidders »
Hi David,
Not sure what year model you have, however you may find this video handy.
https://www.youtube.com/watch?v=kAIohDEEEGM
Regards,
Dom
If you have a 1982 the lens don not come off, you access the bulbs from inside the trunk. The back side of the light assembly is held to the light lens with clips that are part of the lens molding. All the bulbs are mounted on one printed circuit board. The entire board is removed to service or replace a bulb.
I don't have a photo but I'm sure someone will have a good photo for you.
Here is a link showing the driver side printed circuit board
http://www.autoricambi.us/product/RS7-4 ... iver-Side/
spiderman1
Thanks so much for the advice-
DRUMMOND
Post by DRUMMOND »
Hi Spiderman
Your lenses are held on by four nuts on each corner of the lens inside the trunk. You can just unclip the black plastic cover to gain access to the circuit board if you are just changing the bulbs. There is no way to clean the inside of the lenses properly.
This is the only way to get to the inside lenses :D
spiderman1
thanks-I think I will use soap and water and degreaser and a flexible brush and do the best I can
red107
Contact:
Post by red107 »
Here is another option that does work well. Put them in the dishwasher. Just don't use the heated dry mode. Works great.
1981 Fiat Spider 2000
2018 Jeep Wrangler JLU
DieselSpider
Post by DieselSpider »
Just be mindfull that dishwasher detergent can be a bit harsh on the soft aluminum used in some lamp assemblies and can cause some reflective material to turn black.
