I was playing around with the wiring on the lime green 69 i have/ lets just say the wiring is all cut and some missing
Anyways i have the instrument panel completely out of the way and i pulled all the wiring down from behind the dash to the floor so i could sort it out, i notice right along the upper underside of the dash there is a relay ,but unplugged , what would that be for ? Dont see any unused plugs to plug it in, but there many unexplained wires cut, so maybe The Who ever cut that plug connection off, any one have a photo of the wires going to that
Relay
Re: Relay
I am starting to believe there a lot missing for the wiring.i have played with this for at least 8 hrs and I have not got one thing to even work' maybe it just a parts car.there is some rust issues to.
Re: Relay
In the wiring diagram .69 to 73
It shows number 37 flasher,indicator 57
If you look at the full diagram 37 looks like a relay of some sort' can some one help me uderstand what 37 is . Thanks
Re: Relay
I'm not sure this applies to your car. Early Spiders had a round signal light flasher, a rocker switch to turn on the emergency flashers and a separate square flasher that was used in 4 way flasher only.
Hope this helps
Here are some photos of a removed emergency flasher with wires attached.
Hope this helps
Re: Relay
That's true, are hose the two wires that you see sticking out of the ignition switch, i think it a small pick and white, or both white i seenSo Cal Mark wrote:I don't have the diagram in front of me, but it's common to find the key buzzer disconnected
Re: Relay
Also I just looked at the schematic you mentioned and believe the 4 way flasher indicator is item # 59 not 57 that the component list states. Sometimes even factory information has errors.37 flasher,indicator 57
Re: Relay
I seen that, i was saying if you looked at #37 it like it pointing to 57 toospider2081 wrote:Also I just looked at the schematic you mentioned and believe the 4 way flasher indicator is item # 59 not 57 that the component list states. Sometimes even factory information has errors.37 flasher,indicator 57
